Error in FileGDB which is undetectable in a log file
  • Mar 20, 2023 1:33 PM UTC
  • 8 replies
  • 60 views
I ran an FME workbench to create gdb for spatial and non-spatial data (approximately 25 data layers). The process ran successfully and created gdb which has the expected size. Now, when I try to open the gdb, it only shows one table. Although, the log file shows that it reads and writes all the layers successfully. If someone has faced the same issue, I really appreciate your insight on the same.
nielsgerrits
Forum|alt.badge.img+67
Any errors in de FME translation log?
What do you use to check the gdb?
If you use ArcMap or ArcGIS Pro, did you reload after the FME process is finished?
If you read the result using FME Desktop, do you see the data?
  • Mar 20, 2023 2:02 PM UTC
No error in the log file. and when I open the gdb in ArcMap, it shows only 1 layer instead of 25.
nielsgerrits
Warnings?
  • Mar 20, 2023 2:21 PM UTC
None
nielsgerrits
None
What if you read the result GDB with FME?
  • Mar 20, 2023 2:33 PM UTC
Same. It reads one table instead of 25. and the file size of the gdb is over 1 GB, though the table size is less than 100 kb.
nielsgerrits
I surrender :) hard to tell without workspace.
  • Mar 20, 2023 2:53 PM UTC
I am sorry, but I can not share the workbench at this point. Thank you for your time
