Error : Import xml document (schema ) into file geodatabase
  • Jun 24, 2023 9:22 AM UTC
  • 208 views
spiderman
Forum|alt.badge.img+7
Hello ,
i am facing this problem
I would like to import xml document (schema only ) to write into file geodatabase but I got this error
The error number from ArcObjects is: '-2147220735'. The error message from ArcObjects is: {Unable to create object class extension COM component Then feature class name .
Could someone provide me a solution for this problem ?
FME 2021
Thanks in advance
saraatsafe
Forum|alt.badge.img+13
  • Jul 6, 2023 10:12 PM UTC
Hi @spiderman​, that looks like an error on the Esri side. This article from the Esri site provides some workarounds, please give them a try and see if that fixes the issue.
