error adding to feature bufferer is not correct.
  • September 17, 2020
  • 97 views
gisbradokla
Forum|alt.badge.img+17
https://community.safe.com/s/question/0D54Q000080hU2VSAU/the-error-number-from-arcobjects-is-2147220936?t=1600358866820
Is a similar error except mine says
|ERROR |An error occurred while attempting to add a shape to a feature buffer. The error number from ArcObjects is: '-2147220936'. The error message from ArcObjects is: {No spatial reference exists.} However there is a coordinate system just as all the other drawings in my dataset.
this is FATAL and the workbench does not continue
Hi @Brad Nesom​ , could you provide a bit more information on your workflow? At which stage does this error occur? It would be very helpful if you could share your workspace and a sample dataset with us. Thank you!
gisbradokla
  • September 21, 2020
this is difficult to do. I think i have only seen this when running with caching turned on. Also I am running a scan of our entire network. the log does show a specific file in the fatal. but if i inspect it with Map3D it is identical to other dwgs that don't get the error in regards to having a CS assigned in map. It is quite mysterious what fme is doing. The log of the file i just ran (without caching) have these lines...
020-09-18 15:36:27|  2.0| 0.0|INFORM|FME Configuration: Using FME Reprojection Engine
2020-09-18 15:36:28|  2.8| 0.8|INFORM|AutoCAD Reader: Using coordinate system named `WY83-EF' as read from file `S:\\SURVEY\\`COGO DATA\\WYOMING\\WYE_NAD83.dwg'
2020-09-18 15:36:28|  2.8| 0.0|INFORM|FME Configuration: Source coordinate system for reader REALDWG_1[REALDWG] set to `WY83-EF' as read from input data
2020-09-18 15:36:28|  2.8| 0.0|INFORM|Coordinate System `WY83-EF' parameters: CS_NAME=`WY83-EF' DESC_NM=`NAD83 Wyoming State Planes, East, US Foot' DT_NAME=`NAD83' EPSG_QD=`1' GROUP=`SPCS83F' MAP_SCL=`1' MAX_LAT=`45.4' MAX_LNG=`-103.76666666666667' MIN_LAT=`40.6' MIN_LNG=`-106.61666666666666' ORG_LAT=`40.5' PARM1=`-105.166666666667' PROJ=`TM' QUAD=`1' SCL_RED=`0.9999375' SOURCE=`Calculated from WY83-E by Mentor Software' UNIT=`FOOT' X_OFF=`656166.6666666666'
2020-09-18 15:36:29|  3.4| 0.6|WARN |Coordinate system named _coordsys does not exist.
2020-09-18 15:36:30|  3.6| 0.2|WARN |Coordinate system named _coordsys does not exist.
as though the CS is there and it's not there.
gisbradokla
This is the log of running with caching and the fatal error happens.
2020-09-18 07:41:43| 10.1| 0.6|INFORM|Predefined coordinate system `TX-SC' (NAD27 Texas State Planes, South Central Zone(4204), US Foot) matches dataset coordinate system
2020-09-18 07:41:43| 10.1| 0.0|INFORM|The OGC definition of the FME coordinate system '_TX-SC_0' is 'PROJCS["State Plane 27 TX South Central NAD27 US Survey Feet-csref",GEOGCS["GCS_North_American_1927",DATUM["D_North_American_1927",SPHEROID["Clarke_1866",6378206.4,294.9786982]],PRIMEM["Greenwich",0],UNIT["Degree",0.0174532925199432955]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",2000000],PARAMETER["False_Northing",0],PARAMETER["Central_Meridian",-99],PARAMETER["Standard_Parallel_1",28.38333333333333],PARAMETER["Standard_Parallel_2",30.28333333333333],PARAMETER["Latitude_Of_Origin",27.83333333333333],UNIT["Foot_US",0.304800609601219241]]'
2020-09-18 07:41:43| 10.1| 0.0|INFORM|AutoCAD Reader: Using coordinate system named `_TX-SC_0' as read from ESRI_PRJ embedded in file `S:\\SURVEY\\`COGO DATA\\TEXAS\\SCOMAD_OC_2D.dwg'
2020-09-18 07:41:43| 10.1| 0.0|INFORM|AutoCAD Reader: Successfully opened the 'Release2004' AutoCAD file 'S:\\SURVEY\\`COGO DATA\\TEXAS\\SCOMAD_OC_2D.dwg'
2020-09-18 07:41:43| 10.1| 0.0|WARN |AutoCAD Reader: Renamed attribute 'C:\\Carlson' to 'C__Carlson' to remove the following invalid characters '<>/\\&$|:!~ ()"@'
2020-09-18 07:41:43| 10.1| 0.0|INFORM|FME Configuration: Source coordinate system for reader R_6[ACAD] set to `_TX-SC_0' as read from input data
2020-09-18 07:41:43| 10.1| 0.0|INFORM|Coordinate System `_TX-SC_0' parameters: CS_NAME=`_TX-SC_0' DESC_NM=`NAD27 Texas State Planes, South Central Zone(4204), US Foot' DT_NAME=`NAD27' EPSG_QD=`1' ESRI_WKT=`PROJCS["State Plane 27 TX South Central NAD27 US Survey Feet-csref",GEOGCS["GCS_North_American_1927",DATUM["D_North_American_1927",SPHEROID["Clarke_1866",6378206.4,294.9786982]],PRIMEM["Greenwich",0],UNIT["Degree",0.0174532925199432955]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",2000000],PARAMETER["False_Northing",0],PARAMETER["Central_Meridian",-99],PARAMETER["Standard_Parallel_1",28.38333333333333],PARAMETER["Standard_Parallel_2",30.28333333333333],PARAMETER["Latitude_Of_Origin",27.83333333333333],UNIT["Foot_US",0.304800609601219241]]' GROUP=`SPCS27' MAP_SCL=`1' MAX_LAT=`30.966666666666665' MAX_LNG=`-91.96666666666667' MIN_LAT=`27.483333333333334' MIN_LNG=`-106.43333333333334' ORG_LAT=`27.83333333333333' ORG_LNG=`-99' PARM1=`30.28333333333333' PARM2=`28.38333333333333' PROJ=`LM' QUAD=`1' SCL_RED=`1' SOURCE=`Snyder, J.P., 1987, Map Projections - A Working Manual' UNIT=`FOOT' X_OFF=`2000000'
2020-09-18 07:41:44| 10.3| 0.2|WARN |... Last line repeated 289 times ...
2020-09-18 07:41:44| 10.3| 0.0|ERROR |An error occurred while attempting to add a shape to a feature buffer. The error number from ArcObjects is: '-2147220936'. The error message from ArcObjects is: {No spatial reference exists.}
not sure how you want me to send dataset. i could send 1 file but won't be able to send public.
