Editing value in published parameter but getting an error when saving file.
  • Nov 30, 2022 4:25 PM UTC
  • 5 replies
  • 82 views
I would like to update an email address within a published parameter. I am able to edit the value but when I hit the Save button it gives me an error and says it cannot save and save to another location. What am I not doing?
dustin
Forum|alt.badge.img+36
  • Nov 30, 2022 4:38 PM UTC
What does the error say?
  • Nov 30, 2022 4:49 PM UTC
It says, "Cannot save. Try saving to a new location?"
  • Nov 30, 2022 4:50 PM UTC
The Translation log also says:
Failed to save workspace. Error: Workspace Saver: Failed to create temp file "E:\\FME_TEMP\\wb-out-1669826917177_916".
danminneyatsaf
Forum|alt.badge.img+13
Hi @mtung​ I have a few questions to better understand what's happening here:
  • Does this only happen with this specific workspace? If so, are you able to share the workspace with us for testing?
  • Is the workspace originating from a workspace template?
  • How are you opening the workspace? Are you starting FME Desktop first and then opening the workspace from within FME Desktop? Or do you just double-click on the file to open it in FME?
  • Additionally, what version of FME Desktop are you using on your machine?
  • Nov 30, 2022 7:24 PM UTC
Could it be that the E: disk is full?
