Dynamically copy attributes
  • Jun 7, 2021 3:04 PM UTC
  • 90 views
jdh
Forum|alt.badge.img+41
I have a set of csvs where the X,Y fields are named differently in each file, but always in the pattern {prefix}LocationX, {prefix}LocationY. The prefix is unrelated to the filename or any other easy way to predict.
In order to process all the files through the same workflow, I would like to copy the attributes to _x and _y so the rest of the transformers can reference those attributes irrespective of the original names.
Is there a simple way to do so without dropping into python?
Best answer by david_r
What about the BulkAttributeRenamer with regex renaming?
  • Jun 7, 2021 3:31 PM UTC
Forum|alt.badge.img+54
  • Jun 7, 2021 3:36 PM UTC
Two bulk attribute renamers using Regular Expression Replace, one for x, one for y. It looks like it should work on dynamic/unexposed attributes
Capture
jdh
  • Jun 7, 2021 3:40 PM UTC
I forgot the BulkAttributeRenamer has a Keep Original Attributes mode. That will work.
jdh
  • Jun 7, 2021 5:26 PM UTC
Capture
For even more dynamism, one could have a single BAR wtih the Text to find be .*Location([XY]) and the String be _\\1. The downside to that is the attributes are not exposed on the canvas, but there is a very minor efficiency gain to BAR+attribute exposer compared to 2 BARs.
