Dynamic schema definition output issues.
  • Oct 13, 2020 7:44 AM UTC
  • 58 views
damian6105
Participant
Hi
I'm trying to export all of my feature datasets in my ArcGIS Online account to independent shapefiles. I'm using the 'Dynamic Schema Definition' option in my Writer to output a separate shapefile for each of my feature datasets. In my ArcGISOnlineConnector transformer under 'User Content Folder', if I select my root folder, I get shapefile outputs with names that match my feature datasets, but they are all just empty shells, no attributes or geometry. However, in my ArcGISOnlineConnector transformer, if a specify a specific subfolder from my ArcGIS Online account for 'User Content Folder', then the shapefile outputs are all good, with correct attributes and geometry. But obviously I only get outputs from that one sub-folder. I need shapefile outputs from all subfolders.
Can anyone point out what I'm doing wrong please? FME file attached.
Cheers, Damian
rahulsharma
Forum|alt.badge.img+12
Hi @damian6105​ ,
Thanks for filing support ticket, I have tested your workflow with my own AGOL account and everything appears to be working.
Could I request to check if you are able to writer to FFS?
