Duplicate ESRI Create Watersheds tool in FME ?
  • Jul 26, 2021 8:42 PM UTC
  • 9 replies
  • 347 views
simid
Hi all
Trying to generate watersheds based on input points and a DEM. The ESRI Create Watersheds tool does what I need but I haven't been able to figure out how to do it in FME. Any pointers?
Inputs: DEM + Points
Output: Watershed areas per point
ESRI tool https://doc.arcgis.com/en/arcgis-online/analyze/create-watersheds.htm
GUID-4DE64CF6-2A02-46F6-8AE4-4D9227AAB71C-webThank you
gazza
  • Jul 27, 2021 12:11 AM UTC
This isn't going to be easy to do with FME unless anyone has done it before and can share their work. However the two articles listed under 3D Analysis here might help. https://community.safe.com/s/article/how-do-i-do-that-in-fme
simid
  • Jul 27, 2021 9:05 PM UTC
Thanks.. Came across that and went down a rabbit hole without any success... Hoping someone has a solution.
alexlynch3450
Forum|alt.badge.img+16
Not a remote sensing master, but i created a workspace that extracts lake polygon from raster imagery....I think that's what you were asking for...? also not a master in hydrology.
Essentially, I extracted pixels in band 3 that were in range from 0 to 45--based on the logic that bands higher in electromagnetic spectrum tend to be absorbed by water, therefore rendering pixel value near 0.
All you need is (1) known point x,y within lake wanting to extract and (2) polygon around region of interest.
cheers,
simid
  • Jul 29, 2021 9:14 PM UTC
cheers,
Really interesting process there. Has given me some ideas but unfortunately I can't adapt it to what I'm doing. I'm wanting to calculate the "uphill" catchment boundary. Not sure how to explain it but i know the ESRI and Global mapper tools work well. Will keep at it and report back.
alexlynch3450
add dem layer to the workflow.
mdohm
  • Sep 22, 2022 1:38 PM UTC
Hi @simid​ , did you find a solution on how to create watersheds/ catchment boundaries from a set of points in FME?
JennaKAtSafe
Forum|alt.badge.img+9
Hi @mdohm​, do you have a DEM of the area you would like to build your watershed for?
mdohm
  • Sep 23, 2022 8:25 AM UTC
Hi Jenna, thanks for picking this up. Indeed we have LiDAR data available that could be used to create a DEM.
JennaKAtSafe
Though scenario specific, this article should help you get started with the process. I imagine you would need some trial and error with your scenario and your points that you want to use. I would recommend starting a new thread with your question.
