Don't read geometry, only attributes
  • Oct 22, 2021 10:28 AM UTC
  • 268 views
arnold_bijlsma
Forum|alt.badge.img+16
Is it possible to only read the (selected) attributes, and not the geometry?
Quite often, I need to join the attributes from two spatial datasets, but only need the geometry from one. And I am assuming that reading in only the selected attributes without geometry is noticeably faster than reading the attributes with geometry.
Is it possible to read any dataset without geometry (other than reading it with and then doing a GeometryRemover)? And does this apply to all formats?
Forum|alt.badge.img+63
There's a few data types where this would be possible. I'd think any database you can access through the SQLCreator or where there is a non-spatial reader (like Oracle) available. Otherwise, certain formats store their attributes in such a way that they can be read independently, such as Shape (where the attributes are in a dBase file) and Mid/Mif (which uses csv).
p_c_20
Forum|alt.badge.img+9
  • Sep 2, 2025 12:26 PM UTC
Is this possible with FGDB feature classes?
desiree_at_safe
Forum|alt.badge.img+24
Hi ​@p_c_20! I’m not as familiar with this topic, but I’d recommend creating a new post
You might have better luck that way since older threads don’t seem to get as much engagement or eyes as newer ones.
p_c_20
  • Sep 15, 2025 8:12 AM UTC
Done Enable attributes-only reading from FGDBs/shapefiles | Community
Many thanks
