Does the new version of Form support ESRI's new Date (only) or Time (only) formats?
Curious if the new version of Form, 2023.2.1.0 will support ESRI's new Date (only) or Time (only) formats? They are not appearing for me when connecting AGOL, but they appear when I connect to a FILEGEODATABASE.
edgarbaculi
Forum|alt.badge.img+4
Hi @wjloy! We are actively working with ESRI to ensure compatibility. At this time I can share that work is ongoing with the goal of a future 2024 version (timeline has been changing) will address the issue you brought forward. Thank you!
ffossatti_mg
  • October 29, 2024
Hi Edgar,
Is there any news about compatibility with date only fields? I'm on 2024.1.3.0 build 24627 and still miss this.
nielsgerrits
Forum|alt.badge.img+54
I checked in 2024.1.0.0 and I see it implemented:
But not in the Open API version:
ffossatti_mg
  • October 29, 2024
Hi Niels,
Thanks for checking. However, this is not about GDB, I know it it implemented there. It is about AGOL.
nielsgerrits
Ah sorry.
sijmensp
Forum|alt.badge.img+3
  • April 18, 2025
I upgraded a workspace with a dynamic writer. When inspecting the schema before writing there is fme_date and fme_datetime time fields. When writing to geodatabase it created dateonly fields from the fme_date fields when using FME 2024. When writing to SDE we get a ORA-210 / ORA-308 (invalid field type). What is the solution to this problem?
AliAtSafe
Forum|alt.badge.img+23
  • April 24, 2025
Hello ​@sijmensp.
Thanks for asking. We’d encourage you to create a new thread around your question so others may be able to chime in. Thanks for your cooperation.
AliAtSafe
  • April 24, 2025
Hello ​@wjloy, ​@ffossatti_mg, ​@nielsgerrits,
You might of noticed it by now - the Date format should be available with FME Form 2025.0+. Thank you for being patient.
Best,
