Does it possible to get output from pdfpage formatter trnsformer and feed into one sheet of excel file as image
  • Jul 20, 2021 1:22 PM UTC
  • 71 views
gogopotter90
Forum|alt.badge.img+14
i have 3 input to pdf page formatter transformer,after that i got pdf output file and it looks as i wish .
but i have new idea ,that i would like to put the same output as shown in pdf ,feed into directly in Excel sheet .
do we have a method to achieve that ?
because at end i have to take screenshot of pdf file then add in excel sheet manually ,but if there is a method directly ,it will be better.
Thanks for help
FME 2018
gazza
  • Jul 20, 2021 7:22 PM UTC
The PDF Reader has an option to read in the document as an image. You should be able to use a FeatureWriter to write the PDF and then a FeatureReader to read it in as an image.
