Do junctions add to cache
  • Jan 4, 2022 8:26 AM UTC
  • 75 views
So I was given a workbench that was quite extensive and it has a lot of junctions. These junctions were only added so that annotations could be placed on a specific location for readability. This doesn't sit well with me because feature caching is on and the workbench is prone to memory issues already. Also, I don't like the cluttering. But it makes sense to get the annotations where you want. However, after reading several posts it is still not clear to me whether junctions add to the cache or not. Can somebody tell me whether they do add to the cache or not?
Best answer by mark2atsafe
The alternative to junctions is to double-click on the connection lines to add extra vertices. You can control label position like that.
Basically, add two extra vertices and wherever you move them, the label will be in the middle of them.
@geotics​ Yes: Data passing through Junctions is cached when feature caching is on. That will increase the volume of data written to disc, but should not impact memory usage.
mark2atsafe
Forum|alt.badge.img+59
  • Jan 7, 2022 5:35 PM UTC
