distance between 2 opposite building
  • March 26, 2022
  • 7 replies
  • 83 views
boubcher
Forum|alt.badge.img+11
Hello there
we looking to calculate the distance between 2 opposite buildings across a street, if we use a neighborhood finder it will not work
Any idea
Thanks
distance between building
DanAtSafe
Forum|alt.badge.img+22
  • March 26, 2022
@boubcher​ What isn't working with the NeighborFinder? Your buildings and Street center line appear to be parallel to each other.
boubcher
  • March 27, 2022
@danatsafe​  the neighborfinder is getting the adjacent building, not the opposite one, and some time the build are not parallel to the streets
Thanks
danilo_fme
Forum|alt.badge.img+53
  • March 27, 2022
Thanks
Hi @boubcher​
Please, could you share your data?
Thanks in Advance,
Danilo
boubcher
  • March 29, 2022
Thanks
@danilo_fme​
sure please take a look at the sample data
Thanks
geomancer
Forum|alt.badge.img+60
  • March 30, 2022
Your sample buildings are quite simple, without any bulges or indentations, parallel to the street center line, and all at a uniform distance from the street center line.
Also a building is clearly opposite another building, or there is no building across the street.
And the street center line is almost straight.
For your sample data the following steps give you the distance between 2 opposite buildings:
  1. Determine the street facing side of each building
  2. Calculate the center point of this side
  3. Calculate the minimum distance of each center point to the street center line
  4. Create a line from each center point perpencidular to the street center line, and extend a certain distance
  5. When the end point of this line is inside a building, this is the opposite building
  6. The distance between 2 opposing buildings is the sum of their distances from the street center line
OppositesFor more complex data the procedure may also be more complex. Good luck!
boubcher
  • March 31, 2022
@geomancer​
Thanks for the workspace great approach, the only problem is we don't know the buffer value in advance
what we are looking for is to calculate the street width based on the average distance between opposite buildings facing the same street segment which we don't know in advance
the approach will be applied to the entire city
The attached sample will illustrate the data better
geomancer
  • March 31, 2022
That is not quite the same question.
I would do something like this:
1.     Ensure your centerlines layer is topologically correct (make sure they are all connected, and have vertices on all intersections)
2.     Make polygons of the areas between the centerlines
3.     Aggregate all buildings to building blocks within these polygons
4.     Calculate all distances between the different building blocks
5.     Construct the connecting lines between the building blocks
6.     Determine which connecting lines cross which centreline
7.     For each centreline get the length of the shortest crossing line
