delete first char if that is zero or space
rakeshreddy0996
I have House number field but some of values are not valid like start with zeros and spaces
need to remove zeros or spaces from red highlighted columns
Best answer by jdh
You can use the AttributeTrimmer with Trim Type: Left
There is both a space and the 0 character in Trim Characters.
jdh
Forum|alt.badge.img+28
  • August 29, 2019
rakeshreddy0996
could u please give brief... ?
sipsysigh
Forum|alt.badge.img+7
  • August 29, 2019
Edited so that it works now! Sorry for any confusion...
You can use a StringReplacer with the following parameters.
StringReplacer Parameters
The Text To Replace uses RegEx to search for zero or more white space characters and zero or more '0's at the start of the string. The Replacement Text will then replace the matched whitespace and / or 0s and with nothing.
Hope this helps!
Thanks,
Simon
sipsysigh
  • August 29, 2019
As @jdh has said, you can use the AttributeTrimmer. Try with the following parameters:
Your Trim Characters would be a 'space' and '0'
I completely over thought my solution! @jdh has provided a nice straightforward solution. Mine got a little RegEx-y. However, both solutions do what you want, so it's up to you!
rakeshreddy0996
oky sir thank you....
but it delete all zeros in field like
0100 is give only 1 but i need value 100.
rakeshreddy0996
sipsysigh wrote:
Hope this helps!
Thanks,
Simon
bro one more querry,
i work on zeros only leave spaces as it is
  • August 29, 2019
What kind of regex did you use?
