Dealing with nullable attributes in XmlTemplater
  • Mar 24, 2023 10:02 AM UTC
  • 102 views
fme_hans
I am building an xml file with the XMLTemplate. Empty fields are displayed differently than expected. <attribute></attribute> is displayed (exported) as <attribute/>
By first changing empty fields to <attribute>Replace this text with nothing</attribute> and then replace the text 'Replace this text with nothing' with null using the string concatenator, it works. But I'd rather be able to properly set the empty fields in the XMLTemplate. How can this be done?
Forum|alt.badge.img+54
  • Mar 24, 2023 11:06 AM UTC
Null or empty?
fme_hans
  • Mar 24, 2023 12:09 PM UTC
When the fields are empty i get this <attribute/> and i need this: <attribute></attribute>
