DateTimeConverter
  • Mar 27, 2023 12:52 PM UTC
  • 60 views
checcosisani
Forum|alt.badge.img+14
Hi
I need to obtain as output the time %H:%M:%S but without the decimal for second
So the final result must be 11:05:01 instead of 11:05:01.002
thx
Francesco
  • Mar 27, 2023 1:13 PM UTC
Unfortunately you cannot get a timestamp without decimal seconds, but you can use a StringReplacer to remove them with the following regular expression:
\.\d*$
checcosisani
  • Mar 27, 2023 2:26 PM UTC
Hi David
thx I've already found this workoraund in the forum so I'll use it.
Francesco
