Database connection configuration issue when upgrading to new version
  • Mar 15, 2021 6:09 PM UTC
  • 145 views
jiro
I have more than 50 databases connection configured with my FME Desktop 2019 version. I would like to upgrade to FME Desktop 2020. My question is if I migrate to the new version ( FME 2020) will I lose my connections to these databases or will it keep them?
Regards!
mark2atsafe
Forum|alt.badge.img+59
It should keep those connections. The file storing those connections is not stored in the installation folder, so as long as you don't clear out your appdata(?) folder, they will still exist.
Having said that, just to be sure, open Tools > FME Options > Database Connections from the menubar in Workbench. Select all of the database connections and then right-click on them. Now select Export. Then you'll have a backup copy of the connections that you can re-import into the new FME installation if the need arises.
jiro
  • Mar 16, 2021 9:02 PM UTC
Hi Mark,
Thank you for the clarification. I will opt for the option of importing all my connections in a file in xml format before migrating to the 2020 version.
Regards,
