Dark Theme - white Title bar
  • Sep 3, 2019 6:37 PM UTC
  • 6 replies
  • 223 views
philippeb
Forum|alt.badge.img+23
Any idea why my title bar is white?
Just migrated to Windows 10. Using now FME 2019.1.1
Thank you.
Best answer by david_r
The styling of the title bar is handled by Windows itself, not FME.
If you go to the Windows 10 control panel and select a dark theme, then it should be possible.
See for example: https://www.makeuseof.com/tag/5-dark-themes-windows-10/
danilo_fme
Forum|alt.badge.img+58
  • Sep 3, 2019 7:10 PM UTC
Hi @philippeb
I use the FME 2019.1.0.0 and my tile bar is White too:
Thanks,
Danilo
philippeb
  • Sep 3, 2019 7:27 PM UTC
Hi @philippeb
Thanks,
Danilo
This is weird, it was dark for me on Windows 7.
nielsgerrits
Forum|alt.badge.img+67
For me on Win7 / FME2019 the titlebar is white as well. I think this is managed by Windows themes? These settings are locked on my workstation so unable to test changes.
  • Sep 5, 2019 8:13 AM UTC
mark2atsafe
Forum|alt.badge.img+59
I think this is the correct answer. Some dialogs used by FME are controlled by Windows. Switch Windows to dark mode and it will be fine. However, I believe there's a specific setting required to set the color on title bars. Not sure why it's separate, but it is.
philippeb
  • Sep 6, 2019 2:19 PM UTC
Exactly @mark2atsafe
I had to change my “AccentColor” key in the registry (thanks to this article) and now ALL my title bars are dark. That's even better!
I'm happy :)
