cut Lines base on Points
  • Aug 11, 2022 6:23 AM UTC
  • 14 replies
  • 487 views
arash_hokm
Forum|alt.badge.img+8
Hallo FME community,
I have a network consisting of interconnected lines. on the other side I have some points lying on the line. I need to cut out my network based on these points and the line between two points must be aggregated with each other.
Also, PointOnAreaOverlayer couldn't help me.
CutLineI would be grateful if someone can help me how to do this process.
Best answer by geomancer
Replace the Aggregator with a LineCombiner, pass the results and the points to a TopologyBuilder. The Edge port will contain the lines you are looking for. Mind that the points need to lay exactly on the lines for this to work.
LineCombiner_Demo
Different approach: Buffer the points by a tiny amount, clip the lines with the buffers, deaggregate the outside results, use a NetworkTopologyCalculator, and aggregate on the _network_id.
NetWorkTopologyCalculator_Demo
tomfriedl
Forum|alt.badge.img+14
  • Aug 11, 2022 3:48 PM UTC
I think you need the TopologyBuilder, maybe NetworkTopologyCalculator.
arash_hokm
  • Aug 12, 2022 6:50 AM UTC
it didn't work. I need a transformation like Split line at point in ArcGIS
tomfriedl
  • Aug 12, 2022 7:51 AM UTC
geomancer
Forum|alt.badge.img+69
  • Aug 12, 2022 8:47 AM UTC
LineCombiner_Demo
arash_hokm
@tomfriedl​ yes
I have a complicated network. in this network the lines are connected to each other. I first aggregate the lines to get one line then I have 10 points that need to split my line. When I use PointOnLineOverlayer I get the line I had before the aggregator. That means instead of 11 lines, I get 55,000 lines that are not cut out on the point
arash_hokm
  • Aug 12, 2022 9:15 AM UTC
LineCombiner_Demo
I don't know why it doesn't work for me. as you can see i have to get 6 lines as a result but i get 78000 lines.SplittLine
geomancer
  • Aug 12, 2022 9:50 AM UTC
LineCombiner_Demo
What happens when you aggregate the features coming out of the Edge port?
EDIT: No, this won't work.
arash_hokm
  • Aug 12, 2022 9:55 AM UTC
aggregate
geomancer
  • Aug 12, 2022 10:18 AM UTC
LineCombiner_Demo
I have no access to ArcGIS, but searching on the internet leads me to expect it will not aggregate all lines between points. Instead it works just like the PointOnLineOverlayer.
You have a large maze of lines, so many orignal lines will be kept in the results.
arash_hokm
  • Aug 12, 2022 10:29 AM UTC
it looks like i don't have a solution
geomancer
  • Aug 12, 2022 10:46 AM UTC
LineCombiner_Demo
geomancer
  • Aug 12, 2022 10:48 AM UTC
LineCombiner_Demo
Something like this (insert your own data).
arash_hokm
  • Aug 12, 2022 11:15 AM UTC
Many Thanx. it works 😊
geomancer
  • Aug 12, 2022 11:22 AM UTC
My pleasure! 😊
