CsmapReprojector fails with vertical datum (3D reprojection)
  • Oct 27, 2020 8:52 AM UTC
  • 133 views
gerard
Participant
I have two raster files, DEM_epsg25831_orthoHeights.tif and GEOID_epsg4326.tif, and I have to convert from orthometric heights of raster DEM to ellipsoidal ones. I am using CsmapReprojector [3] with FME Workbench 2019.1 but I have problems with vertical adjustment.
I always get this error:
CsmapReprojector: Reproject: Could not reproject the geometry of the preceding feature:
Program Terminating
Translation FAILED.
These are the steps that I follow for vertical adjustment:
1) I have converted DEM_epsg25831_orthoHeights.tif into dtm_epsg25831_orto.asc (Esri Ascii GRID), because CsmapReprojector can only reproject raster files in 2D (that is, with Ignore heights and leave them unchanged) [1].
This is the content of dtm_epsg25831_orto.asc (sample data for test),
NCOLS          3
NROWS          3
XLLCENTER    398955.000000000
YLLCENTER    4624395.00000000
CELLSIZE    5.00000000000000
NODATA_VALUE    -9999
252.71 252.38 251.94
252.97 252.63 252.26
253.23 252.89 252.55
2) I also, I have converted GEOID_epsg4326.tif to EGM96 GRD format using convert-ngrid-to-grd.fmw [2].
3) F‌inally, I have created a .gdc file and I have copied binary ._96 file with .grd file [2, Update note]
I have tried CsmapReprojector with 2D reprojection (epsg2581 -> epsg4326) and works perfect, the problem is with vertical adjustment.
I am wondering if there is something else I'm forgetting to do?
Thank you
[1] http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/csmapreprojector.htm
[2] https://community.safe.com/s/article/creating-vertical-adjustment-grid-files-for-use-wi
[3] https://community.safe.com/s/article/which-transformer-do-i-use-to-do-3d-reprojection-v
Best answer by itsmatt
FME interprets the FME ASCII grid also as a raster - so I suspect this could be where the problem is. You can instead convert to a PointCloud and then apply the vertical adjustment. go back to a raster (NmericRasteriser)
https://community.safe.com/s/question/0D54Q000080hHnySAE/how-can-i-change-the-vertical-datum-vertically-reproject-in-a-raster-dem
Here's an example workflow
itsmatt
Forum|alt.badge.img+48
  • Oct 27, 2020 10:10 AM UTC
gerard
Participant
  • Participant
  • Oct 27, 2020 10:21 AM UTC
Thank you @virtualcitymatt​ , your suggestion works perfect !
