Creating geojson with JSONtemplater
  • Mar 3, 2022 5:03 PM UTC
  • 429 views
I'm currently trying to create geojson with the JSONTemplater to get a txt file at the end of the process. I'm really close to get it but there is something I cannot work around. Here's my final txt file that I have right now :
{ "message" : { "sucess" : true, "message" : "La tâche a fonctionné. Vous recevrez un courriel dans les prochaines minutes. Votre numéro d'analyse est le dc82c137-f34a-4fae-806a-af03f2a16cca." }, "geojson" : { "type" : "FeatureCollection", "name" : "transport_hors_norme", "features" : { "type" : "Feature", "geometry" : { "type" : "LineString", "coordinates" : "[-74.25854312432821,46.386997802914244],[-74.25854690900775,46.38701144003504],[-74.2585653228558,46.387067245480985],[-74.25858324562817,46.38711253856072],[-74.25860564958018,46.38716441447192],[-74.25863316909272,46.38721772574174],[-74.2586621220497,46.387263112167304],[-74.25868443781086,46.387296593907124],[-74.25871705708458,46.38733611753558],[-74.25875451356887,46.38737796040637],[-74.25879054029394,46.38741485104289],[-74.25882794110998,46.38744954337804],[-74.25887278469673,46.38748681119428],[-74.25892123510432,46.387523940955084],[-74.25895746648295,46.38755045206047],[-74.25901329979445,46.38758878797128],[-74.25913982910255,46.38767222825822],[-74.25940083981125,46.3878403504997],[-74.25956300930707,46.38794632092807],[-74.2597132822642,46.38804405737224],[-74.25980446456325,46.38810494537259],[-74.25994679007928,46.38820429067078],[-74.26002858477202,46.388264106803646],[-74.26008679540334,46.38830694274102],[-74.26014523548275,46.38835263111074],[-74.26021766973918,46.3884117330616],[-74.26028515283164,46.38846708997433],[-74.2603526337176,46.388528884057855],[-74.2604341089418,46.38860409168643],[-74.26054188160033,46.388710839434644],[-74.26067563832441,46.388845203790986],[-74.26081683667209,46.388988583263824],[-74.26100973596748,46.38918103030566],[-74.26119530714436,46.38936500992952],[-74.26133267533878,46.389499235362806],[-74.26143564486438,46.38959758259815],[-74.26152130044738,46.38967978216387],[-74.26161511338357,46.389767034919096],[-74.26176513598493,46.38990435210414],[-74.26191175292726,46.39003786589748],[-74.26209795259837,46.39020741666241],[-74.26222865896744,46.39032294090129],[-74.26232545284485,46.39040864791902],[-74.26242027077426,46.39049550385481],[-74.26249516825042,46.39056595432294],[-74.26256457168218,46.39063232466387],[-74.26262011213274,46.39069047560172]" }, "properties" : { "rt_item" : 1, "rts_debut" : "001250315209083", "rts_fin" : "001250315209605" } } } }
The problem that have is there are " before and after the coordinate, which I'm guessing they are read as string feature. My xquery is this at the moment :
  "type" : "Feature",
  "geometry" : {
    "coordinates" : fme:get-attribute("_coordinates")
    "properties": {
  "rt_item" : fme:get-attribute("rt_item"),
  "rts_debut" : fme:get-attribute("rts_debut"),
  "rts_fin" : fme:get-attribute("rts_fin")
There must be a function to get the coordinate of a line feature in the query, but can't find it. Is there a way to remove the " from the result for the coordinate.
Thank you in advance.
daveatsafe
Forum|alt.badge.img+24
  • Mar 3, 2022 10:30 PM UTC
Hi @Ian Gagnon-Renaud​,
Before the JSONTemplater, use a GeometryExtractor to extract the geometry as GeoJSON to the attribute '_geometry'.
In the JSONTemplater, change your template to:
  "type" : "Feature",
  "geometry" : fme:get-json-attribute("_geometry"),
    "properties": {
The fme:get-json-attribute("_geometry") will paste the GeoJSON geometry in without adding any quotes.
You could also use a FeatureWriter to write the features out to a temporary GeoJSON file, then read it back into an attribute with the AttributeFileReader, before sending to the Textline writer.
  • Mar 4, 2022 1:09 PM UTC
Thank you, the geometry extractor work great!
