Creating Channel Networks
  • Dec 22, 2022 4:08 PM UTC
  • 42 views
In QGIS there is a tool to create channel networks across a LiDAR surface. Is there a similar tool or process in FME?
Forum|alt.badge.img+63
Not out of the box, but thinking out loud: if you create a DEM of points, connect each one to its lowest neighbor and then create a network (with network topology) out of those results you could filter out based on Strahler order
  • Jan 9, 2023 9:01 PM UTC
Sounds feasible! I have another question to post regarding merging .asc files grouped according to a site ID and saving out the individual merged .asc files. Once I solve that problem I'll revisit your idea. Need the merged LiDAR surface first.
