create lines between two points from two different shapefiles with base.
rakeshreddy0996
Untitled_FMEcreate line between two points from two different shapefiles.
i have common field (line Numbers) with some of same values, need to draw lines between if the values match with other shape file.
like above figure
need to draw like Yellow color lines.
nielsgerrits
Forum|alt.badge.img+54
You are looking for the LineBuilder transformer. Feed both streams to it, group by common field.
rakeshreddy0996
tq nielsgerrits
