Create Line from Points in One Column and Using 'From' and 'To' Values
  • May 31, 2023 2:45 PM UTC
  • 144 views
parashari
I have a dataset that includes 'from' and 'to' values in separate columns. The 'from' column contains latitude and longitude coordinates. Both 'from' and 'to' values are unique.
My question is: How can I create a line that connects the 'from' and 'to' values in FME? I would like to visualize the connection between these points using a line geometry.
Any guidance or suggestions on the workflow or transformers to use would be greatly appreciated.
Thank you in advance for your help!
Best answer by ebygomm
Use a featuremerger, to get the lat long values for your to points, then a vertex creator with add point to create the lines
Forum|alt.badge.img+54
  • May 31, 2023 3:13 PM UTC
parashari
  • Jun 1, 2023 5:52 AM UTC
Thank you so much @ebygomm​. That worked for me.
