Create buildings to insert them in 3DCityDB
  • Feb 26, 2022 8:17 AM UTC
  • 92 views
I have created a workspace with the help of Mr. Takashi(a person from this forum) that reads the shapefile ,creates buildings then this buildings are separated in storeys and then the storeys are separated in roof,ground and wall surfaces. All this work is attached.I want to find a way to write this information in CityGML (Lod 2).In conclusion i want a workspace that gives me a CityGML writer with the buildings.
Best answer by daveatsafe
Hi @panagiotis​,
Please try the attached workspace. It extracts the Roof, Ground and Wall surfaces based on elevation and surface normal of the faces, then writes to CityGML.
daveatsafe
Forum|alt.badge.img+24
  • Mar 1, 2022 10:30 PM UTC
Hi @panagiotis​,
  • Mar 2, 2022 8:22 AM UTC
Hi @panagiotis​,
@daveatsafe​ Thank you very much!!!!
