Create ACAD blocks
  • Jun 21, 2023 10:01 PM UTC
  • 5 replies
  • 170 views
I want to create blocks from the lines in each layer and give the new blocks the last 5 digits from the original layer name.
so lines in layer 12345xxxx1 will be a single block with a name xxxx1 and the block placed on original layer 12345xxxx1
I got the block created and placed in the correct layer but couldn't figure out how to name it.
output blocks
Best answer by featuremichael
Hey @ghattas111​
Go to the Navigator -> ACAD WRITER ->Parameters -> Advanced -> "Use the block name to create block: from No to Yes!
this should do the work :)
Greeting Michael
caracadrian
Forum|alt.badge.img+23
  • Jun 22, 2023 5:53 AM UTC
Use DWGStyler to give your blocks a name
DWGStyler
  • Jun 22, 2023 6:09 AM UTC
DWGStyler
It didn't work. I got thr same input
featuremichael
Forum|alt.badge.img+9
  • Jun 22, 2023 9:18 AM UTC
Hey @ghattas111​
Greeting Michael
  • Jun 22, 2023 2:41 PM UTC
wow how did i miss this, Thanks a lot
featuremichael
I had the same struggles with AutoCAD blocks ;))
