counter limit
  • Jan 11, 2024 2:44 PM UTC
  • 127 views
alc33
Forum|alt.badge.img+14
Hi!
Do you know if Counter has a limit on the number that are generated (maximum lentgh)? I suppose there is not but I don't find this information anywhere.
Thank you!
Best answer by david_r
It depends on the version of FME, it's either a signed 32-bit integer (verified with FME 2020, 64-bit) or a signed 64-bit integer (verified with FME 2023).
64-bit signed integers have a range of -9,223,372,036,854,775,808 to 9,223,372,036,854,775,807
32-bit signed integers have a range of -2,147,483,648 to 2,147,483,647.
  • Jan 11, 2024 4:42 PM UTC
geomancer
Forum|alt.badge.img+71
  • Jan 12, 2024 8:50 AM UTC
Interesting! I never realized I could set negative numbers with the Counter transformer 😀
  • Jan 12, 2024 9:43 AM UTC
Also be careful if you count past the positive upper limit, FME will silently wrap around to negative numbers and continue counting, without any warning.
Example from FME 2020 which uses a 32-bit counter:
imageThis is pretty much expected behavior for most integer implementations, but it might be something to look out for, at least on older FME versions if you expect to count past 2 billion.
alc33
  • Jan 16, 2024 1:21 PM UTC
@david_r​ Thank you for your answer !
