Convert vertex to point
arash_hokm
Forum|alt.badge.img+8
Hallo FME community,
I have a line and there are vertices on it. I want to have vertex as point. (exactly a tool like "Feature Vertices To Points" in ArcGIS)
Vertex_line I used Intersector and topologybuilder for this and they don't exactly give me the vertex. Attached you find the pictures.
Line_Node
Best answer by ebygomm
If you use a chopper with with maximum vertices set to 1 you will get a point at each vertex
Forum|alt.badge.img+35
  • August 17, 2022
caracadrian
Forum|alt.badge.img+23
  • August 17, 2022
If you need to extract all the vertices of a line use Chopper set By Vertex, Maximum Vertices: 1.
arash_hokm
  • August 17, 2022
Thank you. It worked :)
arash_hokm
  • August 17, 2022
