Convert text from .dwg file.
  • Jun 3, 2021 5:31 AM UTC
  • 120 views
sorinduru
Greeting. I have a file from autocad (.dwg) from which I would like to extract the postal address numbers in the form: NR.20, NR.16a, NR.83
I would like to remove from the column special characters such as: ???, / , or - as well as text names like TEREN VIRAN
For example I have NR-130-TEREN-VIRAN, I wish to have just NR.130
Or: from NR-137/F I wish to have NR.137F
FMEAll the best.
Best answer by caracadrian
One way to do it is to use AttributeSplitter with Delimiter set to "-" folowed by ListExploder, Tester set to Contains Regex "\\d" and a StringReplacer to get rid of the "/".
expode textexploded textYou can concatenate NR. back by any method you like: AttributeCreator, AttributeManager, StringConcatenator, etc.
Am atasat si un workspace care face partea explicata 👍
caracadrian
Forum|alt.badge.img+23
  • Jun 3, 2021 8:19 AM UTC
sorinduru
  • Jun 3, 2021 9:18 AM UTC
Thank you very much!
I modified the script as needed here and there and it works great. Thank you very much!
All the best!2021-06-03_121438
