Convert Long Lat from an excel file to points and place them on a EPSG3857 map
  • Jul 8, 2021 6:02 PM UTC
  • 6 replies
  • 333 views
messagemauri
Hello,
I have an excel sheet with Lon Lat values and I'm trying to convert them to points and then place them on a map that is in EPSG3857, however, the points don't land where they should be. I write it to a shapefile. Any help would be much appreciated.
image_workbench image_workbench2
I've also tried the AttributeReprojector but what do I select for the Source Coordinate System if it's coming from Lon Lat values? I did not find GCS_WSG_1984.
image_workbench3The LON values are displayed without the -, sample: 114.2563, how can I add a dash to makes it -114.2563?
nielsgerrits
Forum|alt.badge.img+67
You need to set the source coordinate system. It's EPSG:4326
messagemauri
  • Jul 8, 2021 6:36 PM UTC
Thanks for your reply @nielsgerrits​
The LON values are displayed without the -, sample: 114.2563, how can I add a dash to make it -114.2563?
nielsgerrits
You can do this in the VertexCreator, x = @Evaluate(LON*-1)
messagemauri
  • Jul 8, 2021 6:42 PM UTC
I tried the following but the results are Null values for the new LON field
sampleImageFME
messagemauri
  • Jul 8, 2021 6:49 PM UTC
 x = @Evaluate(Lon*-1)
This gives me errors when I run the workbench
nielsgerrits
Oops, my bad, needs to be @Evaluate(@Value(LON)*-1)
