Convert Json to xml
  • Mar 4, 2021 10:05 AM UTC
  • 138 views
Hello
I have a metadata json file that I would like to transform to xml.
Is there a particular route using transformers to do this?
I have tried importing the json with a reader the using a xml templater and then writing as an xml but the result is no then viewable in the FME data inspector.
Any suggestions?
Thank you
Forum|alt.badge.img+63
You could simply start by setting up a basic JSON-to-XML translation, no need to use any transformers unless your XML needs to follow certain specific standards.
In that case I personally find it easiest to use the XMLTemplater and work with some sample XML.
  • Mar 4, 2021 10:12 AM UTC
Thank you. I was a bit confused with the other post here that certain transformers are needed.
Will try you suggestion.
