Convert Geographic location to Grid Position
  • Feb 9, 2022 2:48 PM UTC
  • 58 views
I'm using SmartGlobe (Proprietary tool in Microstation) to convert Geographic Points to Grid.
I'm trying to replicate what happens in the background of this tool but I can't seem to find a reprojector/projector to perform this task?
Source file will be an .xml and output will be a .DGN with all the points projected in there corresponding Grid location.
The Tool looks like this
GeoMediaScreenCap
daveatsafe
Forum|alt.badge.img+24
  • Feb 10, 2022 11:14 PM UTC
Hi @tlabelleacc​,
If you know what coordinate system your grid is in, the Reprojector transformer should be able to help you convert from the latitude and longitude coordinates to grid XY coordinates.
