Convert FME datetime to Epoch with milliseconds
  • February 5, 2021
  • 237 views
bgeorges
Forum|alt.badge.img+5
I am reading a feature class stored in ArcGIS Enterprise database and I would like to output a json file.
However, I need the datetime fields values to be in epoch time (with milliseconds) not in FME datetime format.
I am using the DateTimeConverter transformer with the %s Output format parameter
For instance I need this translation
2021020511442300 ---> 1612543463000
However the transformer return the following error:
DateTimeConverter: Failed to evaluate expression '@DateTimeFormat(20210127152551,%s)'. Result is set to null
Format flag '%s' is not supported for input type 'datetime'. Please check @DateTimeFormat() documentation in https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/!Transformer_Parameters/Date-Time-Functions.htm in the subsections 'Arguments' and 'Format String Flags', for supported flags and exclusion lists
  • February 5, 2021
@bgeorges​  You need decimal seconds. Your input date string:
2021020511442300
has 00 as decimal seconds but no decimal point. Either strip the trailing 00 with StringReplacer, or slip in a DateTimeConverter with a format string %Y%m%d%H%M%S00
