Control the writing of attributes
  • August 10, 2018
  • 15 views
Hi. I have multiple connections to my shapefile output.
I want the attribute from one connection that has a value of columns Latitude and Longitude as 0 and 0 to be written at last.
I have already tried using FeatureHolder but, the output is just usual.
Any solutions for controlling the flow of features in the writer?
Best answer by takashi
Hi @dewan, I think the FeatureHolder works as expected if you use it in conjunction with a Tester, as in:
  • August 10, 2018
