Configuration of self defined Published Parameter for multiple selection?
  • Nov 13, 2020 7:15 AM UTC
  • 5 replies
  • 83 views
alfons
Forum|alt.badge.img+7
Hello,
I would like to give the user the possibility to select a certain area when starting the script. The areas were previously recorded in a GDB and provided with a corresponding attribute.
GDB_DefFurthermore a Published Parameter was configured according to the areas and their attributes.
published_parameterAfter starting the script, the user is asked which area is of interest to him and he can select it based on the predefined areas. So far this works wonderfully.after_startMy problem now is that my script only works as long as only one area is selected. If the user selects several areas, which should be possible, I do not get a correct selection.
To test my result I have created a tester with the following configuration.tester_parameterMy question now is, how can I successfully select multiple areas? Many thanks for the support.
Best answer by ebygomm
forgot the workbench
The problem is that your parameter is fetched into an attribute that is on a different feature, you need to fetch the parameter in line
Capture
davtorgh
Forum|alt.badge.img+12
  • Nov 13, 2020 7:52 AM UTC
Hi @alfons​ ,
I tried to reproduce your use case with an example (see attached workspace) and it seems to work correctly: as you can see, if you select choices 1 and 2, the parameter is populated with a string containing the chosen numbers separeted by a space.
screenshot.1screenshot.2I think the test used in your Tester is not correct with respect to how the parameter is populated.
Hope that helps!
alfons
  • Nov 13, 2020 10:29 AM UTC
Thanks a lot for your support. Your sample works perfect alone. If I try to reproduce it in my script I got only a working result, if I run the selection with only one selected area.
I'm not sure, if I'm right but the published parameter provides "only" a string, containing both values ("5 3") of the selected areas? If I use this with my tester, the selection will fail, because it expected a list of the both values (5, 3). How can I transform the attribute into a list within FME without jumping into Python?
I attached my workbench and also the basedatas. Maybe it helps for a better understanding.
alfons
  • Nov 13, 2020 10:30 AM UTC
Forum|alt.badge.img+54
  • Nov 13, 2020 11:37 AM UTC
Capture
alfons
  • Nov 13, 2020 1:29 PM UTC
Thanks a lot for your advice. With your advice and your screenshot I was able to solve the issue. Now it works, how I want.
