Combining and extracting values from multiple netCDF files
  • Feb 3, 2023 10:31 AM UTC
  • 6 replies
  • 198 views
I have 12 netCDF files downloaded from https://data.ceda.ac.uk/badc/ukmo-hadobs/data/insitu/MOHC/HadOBS/HadUK-Grid/v1.1.0.0/1km/tasmin/day/v20220310. Each contains 1km-1km grid values of the minimum temperature for each day of a specific month. I would like to create a single combined file that counts the number of days where the temperature was below zero.
I've tried RasterExpressionEvaluator but I can't get it to generate anything sensible. Can anyone help please?
Best answer by david_r
I've been able to use RasterExpressionEvaluator to generate a 1/0 value based on whether one of the bands in the raster is below zero degrees. E.g.
if(A[1]<0,1,0)
Where I'm stuck is:
  • how to repeat this for each of the 31 bands i.e. A[1] to A[31]
  • how to sum this at the end
Use a RasterBandSeparator before the RasterExpressionCalculator, you can then use the constant formula:
    if(A[0]<0,1,0)
Note the use of band 0, not 1.
Finally try the RasterMosaicker and play around with the Overlapping Values parameter.
  • Feb 3, 2023 11:06 AM UTC
It would be easier to help if you could share the details of what you've tried and explain how the results didn't match your expectation.
  • Feb 3, 2023 11:12 AM UTC
if(A[1]<0,1,0)
Where I'm stuck is:
  • Feb 3, 2023 11:44 AM UTC
if(A[1]<0,1,0)
Where I'm stuck is:
    if(A[0]<0,1,0)
  • Feb 3, 2023 12:55 PM UTC
    if(A[0]<0,1,0)
Thanks, that works. It generates 31 bands with 0/1 values. I've then used RasterBandCalculator to sum these and got the output I needed.
Many thanks for your help.
  • Feb 3, 2023 3:43 PM UTC
    if(A[0]<0,1,0)
Did you try the RasterMosaicker, as I mentioned above? Remember to click "Expand post" to see all.
  • Feb 6, 2023 8:27 AM UTC
    if(A[0]<0,1,0)
Duh, sorry I completely overlooked that line. I just ran it and reassuringly it generated identical results to RasterBandCalculator.
Thanks for all your help.
