Collada (.dae) wrong coordinates and world position
  • Apr 30, 2021 7:31 AM UTC
  • 110 views
Hello.
I have a georeferences Collada file, which is placed in Jersey EPSG:3109. If I load the file in Global Mapper (BlueMarbel) I get the correct position, but in FME the 3D model is being placed in North West Russia: DAEposWhat is the reason for this, and how can I fix it?
I've uploaded the file here: https://drive.google.com/file/d/1ddN133UlQx2BVAqtq7fNzY7k15G6XYjD/view?usp=sharing
Best answer by nielsgerrits
Probably a unit problem. If I scale it with a factor 0.0254 (inch to meter) it does position correctly. EPSG:3109 is a meter system.
2021-04-30_09h42_50
nielsgerrits
Forum|alt.badge.img+67
  • Apr 30, 2021 7:41 AM UTC
2021-04-30_09h42_50
  • Apr 30, 2021 9:02 AM UTC
2021-04-30_09h42_50
Thank you where much! Is the Scaler transformer the best way of fixing this? Is it accurate enough with 4 decimals?
nielsgerrits
To be honest I'm not sure, but I think this should work correctly.
