Clipper not working when I try to clip a raster mosaic to multiple areas using a tile file
Hi, I've been having a problem and I couldn't find any answer that could help me in the forum.
I need to cut a raster mosaic that I did by tiles that I have:
But when I run the workspace, in the clipper the whole image is set to "outside" and I can't figure out why. I also need to transform the raster mosaic to multiple rasters by that tile and with the ID that appears in the image, but I didn't get there since everything goes wrong after the clipper transformer. What am I doing wrong?
imageThanks in advance.
Best answer by danilo_fme
limaia wrote:
Hi, obrigada. You mean the .fmw file? I'll send you.
Hi @limaia​
Please, try to use the custom transformer MultiClipper.
If you won't have a great sucess, we can do a schedule for that.
Obrigado,
Danilo
danilo_fme
Forum|alt.badge.img+45
  • March 2, 2022
Hi @limaia​
Could you share your Workspace?
Obrigado!
  • March 2, 2022
danilo_fme wrote:
Hi @limaia​
Obrigado!
danilo_fme
  • March 2, 2022
Hi @limaia​
Obrigado,
Danilo
  • March 2, 2022
Thank you very much! It worked 😊
danilo_fme
  • March 2, 2022
Oh @limaia​ I'm happy to help you!
