Cleaning up possible duplicate points
  • Jun 29, 2021 5:20 PM UTC
  • 5 replies
  • 298 views
mlupien
Forum|alt.badge.img+7
I have a shapefile with a few thousand points. I would like to be able to remove points that are too close or overlapping on each other.
Usually, the points should be at a minimum of 1 meter of each other. If I have points that are exactly at the same coordinates or within let's say 0.8 meter, I would like to keep only the point with the lowest value into the OBJECTID attribute.
Any idea of which transformer I should use ?
Thank you.
Mathieu.
Best answer by theoconsortech
Hey @mlupien​ ,
I've made a quick workspace to help you. It's not optimized, but I hope it will help you!
Here is my methodology :
  1. Create a buffer of 1 meter
  2. Perform a PointOnAreaOverlayer and create a list to obtain the ID of all the points which are grouped together within a radius of 1m
  3. Identify the point with the smallest ID within the 1 meter radius
  4. Managing the duplicate and keep only the smallest point ID
There are many other ways to make this, but I think this one can work. Also, I don't know what you want to do when this situation happens :
Example
Sorry for my mediocre talents with paint... And hope that will help!
Théo Drogo
GIS consultant​ @Consortech PartnerPortalLogin​
theoconsortech
Forum|alt.badge.img+19
  • Jun 29, 2021 8:10 PM UTC
Hey @mlupien​ ,
Example
Théo Drogo
theoconsortech
@mlupien​ here is my sample data... sorry I forgot to put them on the previous message!
mlupien
  • Jun 29, 2021 8:54 PM UTC
Looks to be exactly what I was looking for !!
Thank you !
I will integrate this into my workbench and see what it looks like.
mlupien
  • Jun 30, 2021 5:53 PM UTC
Thank you @theodrogo​ !
It did the job !
I will use this into some other workbenches to cleanup data.
theoconsortech
@mlupien​
I'm glad it worked!
 Have a good day (and a good data cleaning 😄)!
