Citygml xsd fle as FME writer
  • Jan 5, 2024 12:59 AM UTC
  • 6 replies
  • 200 views
abdullah83
Forum|alt.badge.img+5
Hi... I seek your assistance, sir/ma'am.
I am currently trying to convert IFC to CityGML 3.0. In FME, only version CityGML 2.0 is available. I have found an example on GitHub that includes XSD files for each CityGML 3.0 feature (although it is still in draft phase). My question is, how do I incorporate these files into the FME write library? Your help is appreciated. Here is the GitHub link that contains the XSD files: https://github.com/tum-gis/ifc-to-citygml3/tree/master/xsds
itsmatt
Forum|alt.badge.img+48
  • Jan 7, 2024 1:16 PM UTC
There is a beta CityGML 3 writer in the beta version of FME here: https://engage.safe.com/support/downloads/#beta
I'd give that a go if you're able to.
abdullah83
  • Jan 9, 2024 4:22 AM UTC
ok sir i will try this. its prosibble u install 2 version fme?
itsmatt
  • Jan 9, 2024 3:09 PM UTC
Yeah for sure it is - just make sure that you install it into a new location rather than the default
eldonmarks
  • Mar 5, 2024 11:15 AM UTC
Thank you for the link.
abdullah83
  • Mar 13, 2024 12:52 AM UTC
@virtualcitymatt  Sir, does the new FME 2024 also not have a CityGML 3.0 writer?
itsmatt
  • Mar 19, 2024 7:52 AM UTC
Indeed it looks like that FME 2024 does NOT have CityGML writing yet.
What parts of CityGML 3 do you need that CityGML 2 doesn’t offer?
there is a tool here which you can use to upgrade the CityGML 2 to CityGML 3 here: https://github.com/citygml4j/citygml-tools
You can use FME to write out CityGML 2 and then use this command line tool to upgrade the data to CityGML 3.0
