Change title of open workspaces in Windows taskbar?
geographix
Forum|alt.badge.img+4
I've got several workspaces open at one time, and have a hard time switching between them using the Windows Taskbar because their names are "MULTI - MULTI", "SHAPEFILE - MULTI" etc.
I know Alt-Tab will cycle through, but I usually want to click on the taskbar to bring it to the foreground.
Is there a way to display the file name instead on the Taskbar? Not the directory as these get pretty long. So it shows "land-use.fmw", "birds-of-prey.fmw", "routing.fmw" or whatever.
Here's what I've got open right now:
screen capture of running workspaces
Best answer by redgeographics
There is no setting that controls this automatically. But... it defaults to that name (i.e. inputformat - outputformat) if there's no workspace name set.
Screenshot 2022-11-10 at 16.30.47I know it's a drag, but if you get in the habit of providing a name for your workspace you can control this. It's also good best practice.
Forum|alt.badge.img+50
  • November 10, 2022
geographix
  • November 10, 2022
That was the perfect answer and a little more learned today - thanks @Hans van der Maarel​
The Windows taskbar now shows named workspaces instead of input-output:
Windows taskbar showing named workspaces instead of input-output
You're welcome!
