Change Source from multiple Workbenches
  • Feb 21, 2022 3:04 PM UTC
  • 79 views
My Data moved from Network drive A to Network drive B.
Is there a way to mass change the Source Paths from the Readers in multiple Workbenches at once or do i need to open every Workbench and need to change it manually?
Best answer by nielsgerrits
An alternative is to read workbenches as text, use a StringReplacer to replace the full path. It is hacky, and probably not supported, so use at your own risk. (Backup your workspaces!)
nielsgerrits
Forum|alt.badge.img+67
  • Feb 21, 2022 3:14 PM UTC
caracadrian
Forum|alt.badge.img+23
  • Feb 21, 2022 3:37 PM UTC
I support @nielsgerrits​'s solution.
Read as text, look for
SourceDataset
Your path will be between quotation marks. Do a little transforming on the data, make sure you preserve the line order and write back as text.
Another solution would be reading as fmw (supported) but writing is trickier, writing as xml should work but I never figured it out.
  • Feb 21, 2022 3:39 PM UTC
I agree about this. I think the key to this working is to make sure that the substring to look for and replace must be completely unique, i.e. no risk of accidentally replacing some other but similar substring.
mark2atsafe
Forum|alt.badge.img+59
Hi. I made this my Question of the Week because I thought it was so interesting. You can find a video demo of my thoughts here: https://www.youtube.com/watch?v=bjZRcyYuOjU&t=1611s
In short - I'm not going to say don't use the StringReplacer, but the official solution I think would be to use relative paths, which you'd have to set up beforehand. The video shows how.
