Can I add feature classes to GIS from file paths in a CSV/Excel using FME?
  • Oct 4, 2022 12:23 PM UTC
  • 65 views
I am using Treesize to search company folders for GeoTiffs and want to add to a map to view coverage. I need to have a function to add these Geotiffs from the file path outputted by Treesize.
carmijo
Forum|alt.badge.img+12
  • Oct 4, 2022 12:59 PM UTC
You most certainly can. You will need to read in the csv/excel file, feed the results into a feature reader's initiator port, and set the feature type to the attribute where the data name is located. This way, when each record enters the feature reader, the feature reader will read the data. Then you need to connect it to a feature writer to write the data to your GIS database.
If i've provided something helpful, please upvote the comment. If i've provided a solution, please mark it as 'Best Answer'. This helps the community find solutions when your question is referenced.
If I didn't provide a solution, please let me know if I can help further. Thanks! 🙂
Excellent. Thanks, I'll give it a go.
