Can GIS layers be setup via a relate in a workbench similar to how it is done in ArcMap
  • Mar 15, 2022 11:17 PM UTC
  • 74 views
birgit
Forum|alt.badge.img+25
  • Mar 16, 2022 8:18 AM UTC
Hi mapcafe,
Β
It's not very clear what you are trying to do:
  1. Do you want a relationship class in an Enterprise/File Geodatabase?
  2. Do you want to join these two datasets together in FME and write them to a new feature class?
Β
If the answer is number 1 then the answer is yes but I think you do need the python caller and a custom script though maybe other people know how to do this without the python caller. If the answer is number 2 then you use the Feature Merger or Feature Joiner transformers in your workbench.
  • Mar 18, 2022 3:57 PM UTC
Hi mapcafe,
Β
Β
I need to query a ArcSDE ​layer and a related layer and extract results to a shapefile.
Will python caller​ do that?
