Call a workspace-app with value from another application?
  • Feb 16, 2023 2:05 PM UTC
  • 36 views
essb
Hi
Workflow as of now: ArcGIS Online App, user clicks a polygon and a run button from the poup. The run button calls a workspace and sends the ID from the polygon using a webhook trigger. The scripts runs using the ID from the polygon. This works fine!
But what I need is some sort of confirmation if they intended to run the script, this can't be done via html in the popup. So I was thinking about calling a workspace-app where the user manually have to run the script. So my question is, is it possible to call a workspace app in the same manner as the method Iam using now by sending a parameter to the workspace-app?
If not, can anyone think of another solution?
egge
Forum|alt.badge.img+14
  • Feb 16, 2023 3:38 PM UTC
What about ArcGIS Survey123? Maybe you could use the run button from the popup in your ArcGIS Online App to open a Survey123 Form. This form would allow you to explain to the end user that clicking 'Confirm' means that the ID from the polygon will be used to execute the workspace (and use 'Cancel' if this was not your intention...). Just a thought...
