Calculate volume from pointcloud
  • February 11, 2021
  • 128 views
Hello,
I have a pointcloud scan of a underground tunnel. I would like to calculate its volume. Is this possible? I am guessing I first need to make a water tight mesh out of it.
Kind regards
Mathias
kailinatsafe
Forum|alt.badge.img+21
Hello @mathias.h​ ,
Am I correct to assume this is a terrestrial 3D point cloud? Yes, creating a solid by surfacing the points is perhaps the most accurate approach. However, a good approximation could be made by dividing the tunnels into sections, using the min/max per section (retrieved from the PointCloudStatsCalculator) to calculate volume (the smaller the tunnel sections, the more accurate the results). Just depends what method you'd like to explore.
Here to help,
Kailin
