calculate the distance between points base on the road line on each side
mehar
Hi @takashi
i am totally confused how to calculate the distance between the points of stations
i have tried the neighbor finder but didnt got the result what i am looking
can anyone tell me or help me to finish my task
1- side of the point
2- distance between the points (based on the roads line)
FILES
  • December 4, 2019
If you have proper a proper road topology (e.g. using the TopologyBuilder), you can project each station onto the closest highway segment and then use the ShortestPathFinder to calculate the distance between the petrol stations. That would give you the driving distance between stations.
erik_jan
Forum|alt.badge.img+18
  • December 4, 2019
For the calculation of the side of the road you can use the LeftRightSpatialCalculator transformer.
Then you should be able to use the NeighborFinder (group by the side of the road) or use the option mentioned by @david_r
Hope this helps.
bwn
Forum|alt.badge.img+26
  • December 5, 2019
Was thinking similarly ShortestPathFinder for a topologically connected road, or otherwise use LengthToPointCalculator.
