Calculate image Height/width to fit the bounding box
  • May 31, 2022 4:32 PM UTC
  • 273 views
boubcher
Forum|alt.badge.img+11
Hello there
we are using the staticImageFeatcher transformer in order to get a satellite image that fit the bounding box of vector
the bounding box changes based on each vector's data
is there any way to extract the right value for the  Height/width in the image to set the parameter of the staticMapfetcher dynamic?
imageThanks
Best answer by itsmatt
I think google maps uses a similar tiling scheme to TMS - For each zoom level each pixel has a (somewhat defined size) - I think if you reproject to Spherical Mercator (EPSG:3857) and then calculate the size of your bounding box you should be able to use the following table to calculate the row and height in number of pixels for a given zoom level
https://wiki.openstreetmap.org/wiki/Slippy_map_tilenames#Resolution_and_Scale
for example at level 10 each pixel covers 152.87x152.87 meters (in EPSG:3857) so you can just calculate (xmax-xmin)/152.87 to get the required width.
I don't have a google API token so I didn't test it with the transformer but I think that it should work
danilo_fme
Forum|alt.badge.img+58
  • May 31, 2022 4:56 PM UTC
Hi @boubcher
Please, could you share your Workspace template?
Thanks,
itsmatt
Forum|alt.badge.img+48
  • Jun 1, 2022 12:59 PM UTC
boubcher
  • Jun 3, 2022 2:50 PM UTC
yes, Works,
Thanks to @virtualcitymatt​
