Bulk insert error
  • November 22, 2023
  • 266 views
Using FME workbench 2023.0, I am trying to make updates to some rows in a PostgreSQL table by using the FeatureWriter transformer that takes a csv as the updated dataset as input. However, I am unable to fully run the workbench as it takes an incredible amount of time to run, with the warning message:
"POSTGRES Writer: Bulk Insert is set to Yes, but a conflicting Feature Operation has been detected. Feature type 'ela_master.lim_watr_chem_anal_arbi' has a Feature Operation of 'Update'. Bulk Insert is now being set to No, which can cause insert operations to be much slower"
I have made updates to the exact same table using the exact same FeatureWriter transformer parameters before with no problem... and this is a new issue I'm encountering, and quite frankly I have no idea how to solve it. Can someone please tell me how I can fix this? Thanks.
  • November 23, 2023
Hi @iyaktubay​ ,
​I think Bulk Insert can be applied only if you have set Insert to the Feature Operation parameter in the PostgreSQL writer feature type.
The message is not an error, is a warning saying FME won't perform Bulk Insert for Update operation, even if you set Yes to the Bulk Insert parameter.
  • November 23, 2023
Hi @takashi, thank you for your answer. I am aware that it is not an error, but the reason I called it an "issue" is because it takes an impossibly long time to make updates (I'm trying to update about 12k rows). Do you know of a way to speed the process up? I have tried adding indices to the Match On columns on the Postgres table, but this made no difference.
