Build smooth line
  • Mar 16, 2022 12:14 PM UTC
  • 119 views
boubcher
Forum|alt.badge.img+11
Hello there
we are building line from multiples point
pointusing line builder we get this
line builderusing line smoothness we get this
line resulsas you can see still there is some pics there the line is not very street
how could we improve the result to get a straight line
wsI played with the tolerance but still the same result
  • Mar 16, 2022 12:52 PM UTC
Hi @boubcher​ , a possible way is:
CoordinateExtractor (Mode: Specify Coordinate, Coordinate Index: -1): Extract coordinates of the end point.
VertexRemover (Keep or Remove Coordinates: Keep, Coordinate Index: 0, Number to Keep/Remove: 1): Keep the start point.
VertexCreator (Mode: Add Point): Add the end coordinates extracted by the CoordinateExtractor to form a straight line between start and end points.
Hope this helps.
boubcher
  • Mar 16, 2022 1:26 PM UTC
Hope this helps.
@Takashi Iijima​
you mean rebuild the line from the start and end point of the line right
  • Mar 16, 2022 2:30 PM UTC
@Takashi Iijima​
Yes, that's right.
