Basic JSON to tabular format. I can't work out how to take contents of an array and map to fields.
  • Nov 26, 2020 8:15 PM UTC
  • 62 views
I am new to this and learning but...
I have a JSON object and am trying to extract the attributes to load to PostGreSQL and I am hitting my head against a wall.
The format of the JSON is generally as so:
    model: 1,
    version: 2,
    content: [
            x=1,
            y=2
            x=3,
            y=4
I want to output something along the lines of:
model, version,   x,    y
1,            2,                1,   2
1,            2,                3,   4
For the life of ne I cannot work it out, to me the documentation and step by steps are not clear.
I am using a standard JSON reader. Whatever I try, flattener, fragmentation, I cannot opreate on the content.
I had an instance where I managed to get all extracted using an extractor but this would populate the attributes for each item in the content array and concat together to look like this:
11,            22,          13,  24
The real JSON is a lot more complicated but at this very basic level, I am still not there.
Best answer by jdh
Assuming actual valid json (which the above sample isn't for a couple of reasons) you can use an JSONExtractor followed by a JSONFragmenter to get the desired output.
json
jdh
Forum|alt.badge.img+41
  • Nov 26, 2020 9:16 PM UTC
json
